SOURCE: Dishes and inside the washer are not drying
Make sure that the drain hose is connected as per manufacturer instructions, and that there isn't a direct run down from the sink u-bend to the machine. The rinse agent effects dishes dry but has nothing with the water remaining in the machine. Good luck!
SOURCE: ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
SOURCE: prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
SOURCE: My dryer will not dry
remove the vent tube and run dryer, you should feel hot air, if you do then the vent is restricted. If there is no hot air then the dryer may be built up inside below the lint screen with lint. Here is a website that will explain how to open up the dryer, Hope this helped Tim;
http://www.partselect.com/dryer+open-cabinet+repair.htm
SOURCE: DRYER ISN'T DRYING PROPERLY.
Long dry times are usually always caused by poor air flow. Check the venting all the way from back of dryer all the way to where it goes outdoors,also for lint build up in tube where vent connects to on back of the dryer
