SOURCE: Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
SOURCE: neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
SOURCE: NEFF U1661 insttuction manual
go to www.retrevo.com + www.fitness.manualsonline.com and
download fo free.
God bless you
Testimonial: "Hi Ernesto (hola Ernesto!!) unfortunately is not the manual for the NEFF oven that I have. Gracias Amigo. Thank you. Kind regards, Eddy."
