My Neff U1661 has packed up. Been quoted £600 to have it fixed , replacement cooling fan and some switches!
Anyway I was thinking that I might as well get a whole new unit but I need to make sure it will fit in the existing housing?
Provided I buy another Neff Double Oven do you know if it will fit ? the old Oven is about 7 / 8 years old.
Thank you
For all Free appliance repair videos visit our VIDEO
TUTORIALS1, If the Neff fan motorin the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter. To gain access to the NEFFelement you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the elementyou will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the elementis open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine. 2, If your NEFF fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motoris working you will
see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then
you need To replace the oven fan motoris a little more
expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your NEFF oven thermostat 4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no
heat and no fan then the chances are that someone has put the oven timerinto AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
Is the loose cable on the element , if yes ISOLATE THE APPLIANCE BEFORE REMOVING PANELS
Usually they are spade terminals remove the affending connection, with a pair of pliers carefully press the terminal into itself, not too hard, it will be hard to put back on the element, move the terminal from side to side and ease on with continuous pressure. while you have the back off if you have a multimeter switch the mains back on, use extreme caution select A/C voltage above 250 volts, switch on the oven the fan will start to blow measure across the terminals, if you get a reading of 230 volts A/c the element should start to heat up. If no voltage, send me a reply.
Hope this has been helpful
John
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
