SOURCE: ice maker frost issue
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/0088_4_1.asp#Level1_11
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
Any time a door is letting warm air into the freezer, frost will develop. Manually defrost the area with a WARM setting on a hair dryer. DO NOT OVERHEAT! Inspect the ice chute door for proper closure. Possibly a spring may have broken.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Any freezer without automatic defrosting will build this up over time but a poor gasket seal between lid and chest can accelerate the buildup of frost.
If you want to check the quality of the seal, you could use food coloring (I'd choose green or blue) in water, add a drop of dish detergent and apply this mix to the sealing surface of the chest.
Closing the lid gently and then reopening it, you may be able to see if the contact between sealing surfaces is as it should be.
The mixture will wipe off easily with a clean cloth or paper towel.
SOURCE: frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
