20 Most Recent Neff 3.80 cu. ft. / 108 liter Upright Freezer G4344 Questions & Answers
First, I'm not a Neff representative.
* Check your warranty. Call for support.https://www.neff-home.com/uk/service/support
* Website; https://www.neff-home.com/uk/products/fridges-freezers/fridges
* Manual (official - requires you to register.); https://www.neff-home.com/ie/service/manual
*** The following is for information only.***
* Model needed for specific solution.
* The buttons are for setting the coldness (harder?)
* There are some models that can change the chill "box" section to a freezer.
* Product specs (Official); https://www.neff-home.com/uk/products/fridges-freezers
* Neff Integrated Fridge Freezer K8524X8GB Product Overview (check 0:35) ; https://www.youtube.com/watch?v=NVqMz7cbY4o
* Neff K5920L0GB Side By Side American Fridge Freezer; https://www.youtube.com/watch?v=92ugO2ArjaA
* Neff KA3902B20G Side-by-side fridge-freezer; https://www.ruislipappliances.com/images/PDF/KA3902B20G.pdf
* Catalogs; http://pdf.archiexpo.com/pdf/neff-9796.html
* Products; http://www.jamesratfordbridge.co.uk/downloads/Neff_brochure.pdf
* NEFF KI2823F30G Built In Fridge;http://www.creativelivingni.co.uk/neff9.pdf
* use the posted contacts for specific support.
Aloha, ukeboy57
Neff 3.80 cu.... | Answered on Jul 29, 2018
just do a full defrost(DO NOT USE SCRAPERS/STEAM)and dry after.check door seals sit flush to cabinet.and restart.
Neff 3.80 cu.... | Answered on Oct 01, 2010
Probably your thermostat worst case would be re-gassing the appliance.
Neff 3.80 cu.... | Answered on Mar 19, 2010
It's the number 6.
Neff 3.80 cu.... | Answered on Oct 22, 2009
if it works on superfreeze then the stat is faulty. all that supoerfreeze does is to bypass the stat. easy job
Neff 3.80 cu.... | Answered on Sep 10, 2008
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Neff Freezers | Answered on Dec 04, 2013
do you have the old fuse? If so, carefully read the engraved markings on it
Freezers | Answered on Aug 25, 2019
a general E2 error involves the temp sensor or control board.It may be different for ruey shing. Try unplugging the unit for a minute and plug back in.
how do you know the power is on if all the lights are off?
If you are referring to the main supply, then maybe there is a reset button on the unit. If the unit is running, then without a manual I can't tell what the lights are for either.
Amber light indicates the fast freeze option.
Freezers | Answered on Aug 24, 2019
The model number indicates the cubic footage of the freezer.
Example...model number xyz186xxww.,would be 18 cubic feet.
Post your model number on this thread for an exact conversion.
Freezers | Answered on Aug 16, 2019
Neff 3.80 cu. ft. / 108 liter Upright Freezer G4344 Logo
Popular Tags
6 questions posted
Top Neff Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Neff Freezer Expert? Answer questions, earn points and help others
View Most Popular
Neff Freezers
  • Neff Freezers
Most Popular Question
settings 0 6 coldest
  • Freezers
