Over-level water error on samsung DMT300RFS
My DMT300RFS had the same symptoms, but the float chamber (fc) has a somewhat different configuration, and is white plastic, vs clear.
PULL THE MAIN POWER CORD!!!!
To remove the fc, first go inside the tub, and remove the round fixture that holds the larger chamber on the outside. The fc attaches to it. The round fixture is not threaded, and gentle use of channel locks will pop it off, after about a 1/8th turn (see arrows). My fc could nnot be removed unless the entire assembly is take off the outside of the tub.
After the entire assembly is removed, disconnect any electrical connections. I had two. Release the clip holding the fc to the complete assembly (looks somewhat similar to the one pictured above--thanks capnjosh) then take the retainer clip off the fc feed hose, disconnect the hose and remove the fc from the dishwasher. It's tight!
There are several capture clips holding the top onto the fc, but I decided not to fuss with them (breakage concern) and simply used hot water and dish soap to rinse the fc till gunk stopped coming out. Back together and all seems well!
Best wishes.
