SOURCE: parts manual
hi a bit tricky this one as far as i am aware ram no longer exist your best bet might be to try a want it now post on e bay someone somewhere is bound to have one ,even if you carn't get a complete manual you might be able to photocopy the pages you need best of luck silk090
SOURCE: I have a Buffalo No. 15 floor model drill press
http://owwm.com/mfgIndex/pubdetail.aspx?id=1268
There are other manuals/parts lists for that press on the same site.
Good luck with the restoration!
SOURCE: bought model 3400 skil table saw. have no manual.
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
SOURCE: Where do I get parts for a clarke drill press model bt1029?
the part number I found is BT1029-0038 for the quill spring and you can contact them at 1-800-227-9603 and see about ordering the part. If I have helped you would you please rate this response accordingly and thank you.
SOURCE: Manual Craftman professional router table model
I had the same problem as far as the manual is concerned. I emailed Bosch. They responded and told me this is actually a Vermont American router table, and said they would put a copy of the manual in the mail to me. I haven't received it yet.
