Cars & Trucks Logo
Maksi Raco Posted on Jul 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just got the message:Awd disabled -service required on my Volvo XC60 y2016. Should I stop driving immediately, or continue and go later in a specialized service?
kays
Level 3:
Genius:
  • Volvo Master 1,179 Answers
  • Posted on Jul 07, 2017
kays
Volvo Master
Level 3:
Genius:
Answers
1179
Questions
0
Helped
311835
Points
1715
Basically message is telling you to book the car in for service
Do it soon rather then later to avoid damaging any expensive parts.
tip
Reset service message in Volvo V50, S40, C30, C70 and other
Reset Volvo service reminder indicator or maintenance messages after changing oil, filters and inspecting brakes and suspension.
  1. Press and hold trip reset button,
  2. turn on the ignition,
  3. wait for the yellow warning light to start blinking,
  4. release the button and wait for confirmations sound,
  5. turn off the ignition,
  6. turn the ignition back on to check if the service message is gone.
This procedure will reset messages:
  • TIME FOR REGULAR SERVICE
  • ENTRETEIN REGULIER NESECC
  • SISTEMA MOTORE PROSS.TAGLIANDO
  • STANDARDWARTUNG DURCH FUHREN
  • TAGLIANDO SCADENZA
  • TIJD VOOR REG SERVICE
  • WYMAGANY PRZEGLAD OKRES.
  • ZEIT FUR REGELM. WARTUNG
This also works in any other modern Volvo car, like: C30, C70, S40, S60, S80, V40, V50, V60, V70, XC60, XC70, XC90.
More details over here: Volvo reset service reminder indicator
1helpful
2010 Volvo XC60. The blower climate control has no air blowing out, but blower works with jumper wire?
And a third car you are working on today, Volkswagen City, and Oldsmobile Alero. Are you a mobile self employed mechanic with no clue :>D
First check the fuse for the blower, the climate control and the body control module.
Volvo XC60 (2009-2012) fuses and relays
https://fuse-box.info > volvo > volvo-xc60-2009-2012-...
Here you will find fuse box diagrams of Volvo XC60 2009, 2010, 2011 and 2012, get information about the location of the fuse panels inside the car, ...
Volvo XC60 (2010) - fuse box diagram - Auto Genius
https://www.autogenius.info > volvo-xc60-2010-fuse-b...
Apr 1, 2017 - Volvo XC60 (2010) - fuse box diagram · Fuses - engine compartment · Fuses - glove compartment · Fuses - cargo area · Module A (black) · Module B ( ...
1helpful
My 2010 volvo xc60 fuel gauge only works intermittently
Hi You can solve this problem by going to the quick link below. I am sure you will be able to fix it easily.
https://www.reliable-store.com/products/volvo-xc60-2009-2010-complete-workshop-service-manual
2013 volvo xc60 light failure message won't clear after bulb has been replace and is in proper working order
Make sure you replaced the correct bulb. Look them all over. Volvo uses the same bulb name for more than one bulb that serve the same function. Also, make sure it's a standard bulb with filament, NOT an LED replacement. LED bulbs don't have the same resistance, and the car can't tell there is a bulb there.
2017 Volvo XC60. Car lunges forward when foot is taken off brake and green A light comes on dash
Hello Kay,
Is it still under warranty? If yes, then immediately take it to your dealer for assistance. In fact, even if not under warranty, take it to your dealer or an authorized Volvo service center for assistance.
2answers
Just bought 2003 Aztec and the AWD is disabled how do i know if something is wrong . We could not find AWD button ? ??
AWD Disable indicator
The AWD Disable indicator is located in the instrument panel cluster. This lamp is used to inform the driver that the AWD system has been disabled and no torque will be applied to the rear wheels during a slip condition. The AWD Disable indicator is controlled by the powertrain control module via a class 2 message.
Powertrain Control Module
The powertrain control module monitors the data from the ABS controller and Rear Drive Module (RDM) for proper operating conditions. If inappropriate conditions are present the PCM commands the differential clutch pump actuator check valve closed, disabling the AWD system. The PCM also commands the AWD Disable indicator on.
Is the All-Wheel Drive Disabled Indicator Always On ?
Is
2wd vs AWD
Page 13 of owner's manual says:
AdvanceTrac
(if equipped):
Illuminates when the AdvanceTrac
system is active. If the light remains
on, have the system serviced
immediately.
AWD locked (if equipped):
AWD
Illuminates when all wheel drive
LOCKED
(AWD) is engaged/activated. If the
light continues to flash, have the
system serviced.
Page 224:
ALL WHEEL DRIVE (AWD) SYSTEM (IF EQUIPPED)
Your vehicle may be equipped with an All Wheel Drive (AWD) transfer
case. With the AWD option, power is supplied to all four wheels
automatically with no need to shift between two-wheel drive and
four-wheel drive. If your vehicle is equipped with the AdvanceTrac
stability enhancement feature, you can change AWD modes, if desired,
by selecting AWD options through the message center.
For the lubricant specification and refill capacity of the AWD transfer
case refer to Maintenance and specifications chapter.
If your vehicle is equipped with AWD, a spare tire of a different
diameter than the road tires should never be used. Such a tire
could make the vehicle difficult to control as well as result in damage
to driveline components.
Utility and four-wheel drive vehicles are not designed for
cornering at speeds as high as passenger cars any more than
low-slung sports cars are designed to perform satisfactorily under
off-road conditions. Avoid sharp turns or abrupt maneuvers in these
vehicles.
The following sections, Normal operation, Autolock operation and
Disabling AWD, apply only to vehicles which allow the driver to change
AWD modes through the message center.
Normal operation (vehicles equipped with AdvanceTrac
During normal operation:
• the AWD system is in AWD AUTO mode (AWD LOCKED will
illuminate in the message center for four seconds when you first start
your vehicle). The AWD LOCKED indicator in the instrument cluster
will also come on.
• AWD AUTO mode can be overridden by pressing SETUP in the
message center. When you first press SETUP, AWD <AUTO> will be
displayed, then if you press RESET within four seconds of pressing
SETUP, AWD <LOCKED> will be displayed. AWD <LOCKED> provides
power to all four wheels constantly which allows you to operate your
vehicle in severe winter or off-road conditions such as deep snow, ice
or shallow sand. It is not recommended that you use AWD <LOCKED>
on dry pavement.
Page 225:
• AWD <LOCKED> can be cancelled by pressing RESET in the message
center. (The AWD LOCKED display in the message center will then
turn off and the display will return to AWD <AUTO> for four seconds
when the shift is complete.)
Autolock operation (vehicles equipped with AdvanceTrac
If the AWD system begins to overheat, the system will place itself in the
Autolock mode:
• the AWD LOCKED indicator light will illuminate in the instrument
cluster and AWD DISABLED <LOCKED> will be displayed in the
message center.
• AWD LOCKED will be displayed in the message center for four
seconds and a warning chime will sound. This condition may clear
without any action being taken by the driver.
• the AWD LOCKED indicator light in the instrument cluster will turn
off when the AWD system cools down.
• When the system is sufficiently cooled down, AWD AUTO RESTORED
will appear in the message center for four seconds and a warning
chime will sound.
Disabling AWD (vehicles equipped with AdvanceTrac
When a problem is detected in the AWD system:
• the AWD LOCKED indicator light in the instrument cluster will flash
eight times every two minutes in the message center.
• The message center will then display AWD DISABLED for four
seconds, then SEE OWNER'S MANUAL. A warning chime will also
sound. The warning displays and chime will continue until RESET is
pressed (which will clear the message from the display).
• AWD LOCKED can still be engaged by pressing SETUP (the message
center will display AWD <DISABLED> LOCKED), then pressing
RESET. The AWD LOCKED indicator light will illuminate in the
instrument cluster and the message center will display AWD
DISABLED <LOCKED>.
• To disable AWD, press RESET. The system will go back to AWD AUTO
mode momentarily, then the AWD LOCKED indicator light will flash in
the instrument cluster eight times every two minutes. The display will
then show AWD <DISABLED> LOCKED for four seconds and then
turn off.
Page 226:
• If a serious problem occurs with the AWD system, the AWD LOCKED
indicator light in the instrument cluster will flash 10 times every two
minutes. The message center will also display CHECK AWD and a
warning chime will sound. You can press SETUP to check the status of
the AWD system (which will display AWD <DISABLED> LOCKED),
but the AWD system will be disabled until the system is serviced.
Driving off-road with truck and utility vehicles
AWD vehicles are specially equipped for driving on sand, snow, mud and
rough terrain and have operating characteristics that are somewhat
different from conventional vehicles, both on and off the road.
When driving at slow speeds off-road under high outside temperatures,
use 1 (First) gear when possible. 1 (First) gear operation will maximize
the engine and transmission cooling capability.
Under severe operating conditions, the A/C may cycle on and off to
protect overheating of the engine.
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
