Cd player works and maybe 2 am channels
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
SOURCE: resseting the preset channels
Please download user manual of Aiwa XR-MN5 from here. This will help you to set new stations presets.
SOURCE: 1999 Saturn SL AM/FM radio quit working?
check radio antenna. could be loose connection or antenna missing or broken.
SOURCE: 2001 Ford Taurus Radio doesn't work but CD player does!
Possible Antenna Disconected ? Or Plain Radio FAILURE Seen this Before and Radio Muse be Replaced, IF it"s NOT Antenna
SOURCE: Radio doesnt work in FM mode
Before you replace it, remove it from the dash and check to see if the antenna is hooked up to it. Sometimes it can come loose and that's your problem. It's a thick black cable with a single prong out of it. It connects directly into the stereo. Good luck!
