I have a Pfaff 7570 machine and recently the presser foot has begun to move in slow motion or needs me to actually push the foot down?
I have no idea if a grandchild moved or twisted a knob or button? It can be pushed down manually. The lever to raise and lower it feels differently too
https://www.pfaff.com > en-ca > machines
The result is a feat of technological excellence destined to exceed the aspirations of today's sewing, quilting and embroidery artisans.
Assuming that the presser foot lifter is working, this shouldn't be a fatal error. The presser foot has to be down to sew. The lifter needs to be in the down position to put the foot down.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
If it's been a while (more than a year) since you've had your 7570 serviced by an authorized Pfaff tech, it's likely that it's just gotten gummed up and needs some attention and adjusting.
It's definitely fixable, but not something that you'll likely be able to do yourself - some of those parts are just not easy to get to and the lubricants needed aren't directly available.
Hope this helps, Kim & Linnette www.sewingexpressions.com
