SOURCE: Liberty condensate pump LCU-20S never shuts down and is loud
Had the same problem today. What I did to fix this was to disconnect the unit and shake it so that the float became free. Once this was done, I reconnected the power and drain tube and PVC lines and primed the pump with about 32 oz of water to activate the pump. All works fine now.
SOURCE: i have a sfw 55
It may be the type of coal you're burning. Have you tried burning anthracite coal rather than Bituminous coal? It's a little more expensive, but it burns cleaner. Also, you may need to open the air intake a bit with what you're currently burning. That way it will burn a little hotter and hopefully cleaner.
SOURCE: should this boiler be installed
Hello
Yes you will need to run condensate lines to the drain,pvc is fine.
Once you start up and see how much water is generated you will see why.
During the reburn of the natural gas there will be alot of moisture.
You need to contact local code enforcement to make sure that would meet building code
