If you are low in cash to affording to get another Range/Oven. Then measure The Two sides, and then look on The Inside for where the hooks are placed that hold the oven door to the casing, and measure them as well from the outside corners, to the slot that the Hooks hold onto. From there Look for to see about the Light button pusher Place where it is centered and write all of this down in a pad with a pen. Then look on the back of the Range/Oven for the Make and Modle #'s and write them down. For you will need these later on. Afterward, if you're not picky about the outside color or design of the door. Then go to your local Goodwill and/or other Thrift Stores by phone, and while letting your fingers do the walking. You tell the head Thrift Store Main Manager what Make, Color, Modle
#'s & Measurements you have for all of the details that you need. Remember that you are recycling old worn out and misused Range/Oven for their parts. So if they give you the OKeDoekey on that they have that same model. Have them put it aside, and give them a timeline when you will be definitely down there to recheck it out and buy it for that part. The Rest of if You will have to scrap with a Recycle Center after You hire Your Brother or Best Friend can help you pick up the Range/Oven and take the Casing to the Recyclers for the amount of money you owe him for the ride and his troubles to helping you to solve your problem's.You might as well be taking out that Amazon.com Credit Card and buying a Used Range Oven through them. I hope this helps you Jackie.
