Home Security Logo
A
Anonymous Posted on May 02, 2017
Need key for Brinks Model 5080 fire safe - Honeywell doesn't have that model available. It's i....n series skipped when they bought Brinks. I have combination, but need key.
Lock # is 5445 in my Brinks fire safe...need a key that will work...or some way to get inside without destroying the safe.
john h
Level 3:
Top Expert:
  • Honeywell Master 29,494 Answers
  • Posted on May 02, 2017
john h
Honeywell Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7561091
Points
193449
Since manufacturer cant assist you will need a locksmith
Brinks Safe 5190. How to open with lost key and no combination.
You can't. This safe has a rotary combination lock and a failsafe key. The key is your insurance if you can't get in.
Call a local locksmith, for what will probably be destructive entry unless you have the serial number of the safe. A GOOD locksmith may also be able to impression a key for you. According to this you can get keys on proof of ownership.
https://www.lockpicking101.com/viewtopic.php?f=36&t=64109
How can I get the combination for our brinks fire safe model ...
Answers https://www.answers.com > Hobbies > Guns & Weaponry
Sep 15, 2023 - Get the model and serial from your safe as well as the key number. Call Honeywell @ 800-223-8566.
Spanish please? I have a BRINKS safe security 5054 152618 key1413. can you help me to open
https://www.justanswer.com/general/3968h-brinks-safe-model-5054-lost-combination.html
Con Google Translate, usted puede trasducir entre ingles y espanol.
http://translate.google.com
Aqui es la resulta:
Tengo un Brinks Safe Model 5054 y he perdido la combinaci?n ... Tengo un Brinks Safe Model 5054 y he perdido la combinaci?n. El n?mero de serie es x. La clave tiene un n?mero que es 63562. El n?mero en el candado es 1212. Por favor, h?game saber c?mo puedo obtener la combinaci?n. Gracias Sylvia Banta
Comparte esta conversaci?n
Brinks ahora es propiedad de Honeywell y el n?mero de esta caja fuerte (para Honeywell) es 2054. Si ya no tiene el manual del propietario que vino con su caja fuerte, que proporcionar?a la combinaci?n, puede comunicarse con la compa??a al 1-800-223-8566. y solicite que le env?en la combinaci?n. Deber?a proporcionar el n?mero de serie de la caja fuerte, as? que me alegro de que la tenga, y tambi?n se le puede exigir que demuestre la propiedad con una carta notariada. Sus horas son de lunes a viernes de 8:00 a.m. a 4:00 p.m. (hora del Pac?fico); o puede contactarlos por correo electr?nico a: [email protected]
La direcci?n del sitio web de Honeywell es HoneywellSafes.com
http://www.honeywellsafes.com/support-new_cp.aspx
P?ngase en contacto con First Alert Customer Assistance en: 1-800-323-9005
Presione "3" para Cajas fuertes
Si no se aplica ninguna de las condiciones enumeradas, haga clic a continuaci?n:
CONT?CTENOS
http://honeywellsafes.com/support_cp.aspx
http://honeywellsafes.com/UserFiles/ContentPageFiles/ORDER%20REPLACEMENT%20KEYS%20&%20COMBINATIONS.pdf
1helpful
We have a Brinks fire resistant safe model 5059/5063 and can not get into it. Lost the key and the combination. What can we do? Joyce
You do not need to go to a locksmith - you can get a new key much more inexpensively by contacting Honeywell (the parent company for Brinks safes) at 1-800-223-8566
When you call Honeywell, you will need to provide your safe's model number (5059) and the serial number (usually found on the right of the safe, near the model number).
At the company's discretion, sometimes they require a notarized affidavit confirming ownership. There is a fee for a replacement key (it was $15 last time I checked, but may be higher now), but it is much less expensive than going through a locksmith (who will generally just do the same thing as described above!)
1helpful
I have a brinks safe that has a combination lock and a key but i cant remember my combination and was wondering how I can reset it. Model number 5059
Each Brinks 5059 safe has a different default combination, so to get the original combination you must either contact Honeywell (the parent company for Brinks safes) at 1-800-223-8566.
You need to send them a notarized letter showing safe ownership in order to get the master combination. When you call Honeywell, you will need to provide your safe's model number, the serial number (found on the right of the safe, near the model number), and your key number.
Is there a default combination for brinks model 5054 safe
Contact brinks they may have a master code to unlock your safe...or try a good lock smith,they may have access to the code.
11helpful
2answers
14helpful
4answers
I have a brinks home security safe model 5059 key 3206
I'm pursuing a solution to the same problem. So far, I'm told that Brinks safes are made by Honeywell/Sisco. Call 1-800-832-5834 for customer service. They will play you a recording that will tell you what you need to do to get a replacement key ($7.95 - $10.95)
24helpful
9answers
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Top Honeywell Home Security Experts
Jay Finke
Jay Finke
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
