SOURCE: Micro SD NOT WORKING (SONY ERICSSON W580i)
turn phone off, insert micro sd card in - logo side up and reboot. worked for me. i experienced the same problem.
SOURCE: Lost of space on micro SD card
Yes you can get your space back.
Let me clear you first you lost the space due to while system is writing data in your SD micro card it is suddenly ejected or disabled.
You will do this method to retrieve you data back. You will need some things
1. Card reader for SD micro memory.
2. A software called D M comes as Hard disk tool it comes in bootable cds.
You will remove your H D for safe side to protect your hard disk data.
Put your SD card in card reader and start you computer with bootable cd that contains D M software.
When your system is boot from cd run D M and go to option in D M erase all data. This will retrieve your all space from SD. Remember you can do the same thing with Hard disk if there is any bad sector or some space not avalible or disk partion is not able to delete by any softwares.
Hope this will help you, If you have any problem regards this you can reply to me other wise don't forget to make ansewer my thread.
Regards
nidostyle
SOURCE: not recognizing micro sd memory card
the M2 card used in this phone is little expensive but SD card will not work for sure.
Also the cheap M2 cards have problems of saving images to un-readable format.
make sure you use sony original or Sandisk card which i've seen working fine on this model.
SOURCE: inserting a 2gb micro sd mem card in lg webslider to have xtr spa
You have to move each song/file to your external memory straight away after recieving it via bluetooth because it goes straight onto your phone memory. Seach your phone memory and move all photos, videos, music etc to ext.memory by selecting the file-select options in lefthand corner- move to external memory. If your phone cannot find your external memory then you havent formatted your memory card. Go to Settings-Memory Status(way way down the bottom of list)-External Memory-Format(lefthand corner). Just remember to move each file to ext. mem. straight away.Its a pain but you have to do it manually, the phone doesnt do it for you.
SOURCE: lost all memory on a 64gb sd micro card after formatting
No, you didn't loose memory. You just have to reformat it. When you do, check if you can change the total capacity with drop down menu, also try settings it to FAT32.
If not, you could use another computer or even a portable device like cellphone or camera to try and format it.
Don't worry, you cannot 'loose' the 64gb.
Testimonial: "when I inserted the card into my Galaxy 3 phone it was possible to format it back to its 64gb volume. I believe my problem with the PC Windows 7 had to do with using a card reader that does not work with SDXC cards. I will shop for a better reader and recheck after that. thank you"
