Computers & Internet Logo
Bryan Bordelon Posted on Apr 20, 2017
My weighmax nj100 is showing unse,what does this mean and how f I I fix it. Thanks
WeighMax W-EX650C pocket scales. When I turn them on reads "ERR" then shuts off. How do I fix them please?
Question edited for clarity and add maker.
The most likely reason is it needs new batteries. The secondary reason would be bad connection inside. A final answer is putting it on a surface that is not flat and stable coupled with a non-distinct switch on.
https://www.google.com/search?q=WeighMax+W-EX650C+reads+ERR
How do I remove the batteries to replace them?
Hello, Joanne -
WeighMax manufactures more than one model of bathroom scale. See:
http://www.weighmax.com/products/bathroom-scales-1.html
Not all the WeighMax bathroom scales take the same kind of battery. If your scale is one of them listed on the web page cited above, click or tap on the link for the information on the scale and look for the information on Power to find out the kind of batteries needed.
I do not find any instructions for where to find the battery compartment on any WeighMax bathroom scale. Therefore, I suggest you contact WeighMax Technical Support and ask. You will probably need to provide the model number of your bathroom scale. This is the link to the WeighMax Contact Us web page:
http://www.weighmax.com/contacts
Best wishes.
2answers
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
THe icemaker in our Kenmore side-by-side, model 106.57362702 is not working. The arm will not go into an upright position, but, rather, is in the down position.
if the bin arm will not go in the up pos . the i would belive the head has broken dirve parts inside / i would replace the icemaker . . mm hope this helps feed back pls and thanks for unsing fix ya ..
Have a WeighMax postal scale..how to I cange from kg to pounds?
I had mine set to ozs for over a year and then it changed to kg. Couldn't reset it by hitting the button, so I removed the battery and then put it back in. It reset it to ozs.
Screen does not show whole picture
i would like to first about which type of Television reciever u r unsing.
2answers
Browsing and memory problem
Not really t means you have too much memory used up with rintones/pics or applications try deleting unsed stuff or upgrade to a phone with more mem...
Grand Canyon Tech
Grand Canyon Tech
