Is it possible the rinse aid is just leaking out somewhere when I put it in & not actually doing what it should in the wash cycle? Many thanks
SOURCE: It's Leaking Water!
Most common reason is that the lower spray arm splits on the seem and sprays water under the door, to proove if it is this remove lower spray arm and run through program if no leak fit new arm. Regards Advisor
SOURCE: Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
SOURCE: Westoint Dishwasher
Hi jannewbery,
I'm Harvey the Master Plumber.
Your problem is: You have looked in the manual under troubleshooting tips, but didn't find anything on the problem. The dishwasher goes into cycle,but during the wash cycle it stops,makes alarm and the wash and rinse ligts come on. And now you can't even find the product on this site.Westpoint Dishwasher WQP12-9240.
Thankyou Your dishwasher is stopping at stage 2 of the programme after beeping once. Quite often the detergent flap doesn't open. Am at your wits end and threatening to leave home!!!! The machine is less than a year old. PLEASE HELP!!!! Thank you.
Don't leave just yet. It sounds like a control problem. The d/w should still be under warranty if it is less than one year old. Use it before it runs out. I don't recomend this type of repair for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
SOURCE: belling dishwasher IDW604
there is a small plastic catch in the door side of lock which loks arround the bar on the washer side of the lock somtimes it stays in you can click it out with a knife or simillar sould work fine after that
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
