SOURCE: How to fix a leak fuel from the carbuator or primer for a atv arctic cat 500 2005
YOUR GOING TO HAVE TO TAKE APART AND PUT A BIGGER RUBBER O RING INTO IT.
SOURCE: My 1998 500 arctic cat four- wheeler will not
Sounds more like a fuel delivery issue, Professional carb cleaning needed and a new spark plug!
Verify that your getting spark, and carb may need cleaning?
electrical, and fuel systems on snowmobiles are sensitive, because they are exposed to winter weather....
SOURCE: 2006 arctic cat 600vp green no spark after sitting a month
Have you changed sparkplug and empty and put new gas in.
Need to clean that carb thoroughly. Clean or replace air filter, check gas tank vent on cap, make sure you have a good fuel stream coming out of the fuel petcock. The old gas could have clogged the petcock filter. In the picture you can see the arrows pointing to the reserve and the main. This is where the fuel comes in and it is a very fine "plastic screen mesh". This can become clogged. The one pictured us from a cat.
Testimonial: "Where is the petcock filter?"
It runs to good to be the timing for about 30 minutes before it dyes
