Computers & Internet Logo
F
FINERS CRYER Posted on Mar 23, 2017
I HAVE PURCHASED PRINTMASTER VERSION 17. I AM COMPUTER ILLERIATE. CANYOU HELP ME INSTALL THE PROGARAM? FINERS CRYER
JD Bergstrom
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Mar 23, 2017
 JD Bergstrom
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
2074
Points
22
If you are not installing this on a computer that has windows XP, you may have to do some special install procedures, or it may not be compatible with your system, this software is not compatible with Windows 10
I have Printmaster Platinum 17 on my computer. It has stopped coming up and will not reload. Is there a site where I can download it again? Maybe directly from the internet?
Lest's star by telling you neither me nor FIXYA had ever released any version of Printmaster Platinum 17. OK? So, if you want to contact authors of this sofware, ENCORE SOFTWARE
Encore Official Site Download Top Software Hoyle Card Games The Print Shop...
Now, HAVING SAID THIS, dd you use ever Printmaster Platinum 17 with Windows 7? I understand that it is for Windows XP.
I'm no sure what kind of a mess you made with it uninstalling or removing but well, try to reinstall your original SETUP version in Windows XP COMPATIBLITY MODE
Befor you instal it cricght click setuo, select Properties, click on tab Comatibility and select option Windows XP Comatibility mode
If won'r work, I find no way to help you,
1helpful
Is there a patch to have Printmaster Platinum 17 work on Windows 7
There is no patch/update available from Broderbund, to make PrintMasterĀ® Platinum 17 Full Version compatible Win7.
2answers
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
All the best with your install.
Kind regards
Registration number
you can download your full software from the web but sometimes the softwares are download with viruses so take care.
2helpful
Is there a manual with the Printmaster 17?
you can download the manual from my website
http://tricia8765.fatcow.com/COMPUTERTRAINING%20MANUALS.htm
you will see it is around the fourth entry on the link
Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
2answers
Printmaster 17 won't open projects created in printmaster 11.
printmaster 1 was for windows 98, ver 17 is for XP. it depends where your saved projects are. if they are on CD media then that is READ ONLY and they must first be transferred to a C:\ drive and their ATTRIBUTES for each and every file/folder of the project need to have the Read Only attribute removed. you can do that via CMD.exe eg if your project was inside a folder called c:\myprojects\????? then you would type in ATTRIB/S c:\myprojects\*.* -R then your projects might be valid as they could be UPDATED/Altered by the new version but thats just a guess.
2answers
Installing program - BRODERBUND PRINTMASTER PLATINUM VER. 18
Check this link for the step by step way in installing this software but this is for 'PRINTMASTER' PLATINUM VERSION 17 but dont worry its just have the same procedure in installing the 'PRINTMASTER' PLATINUM VERSION 16, this is the link
http://support.broderbund.com/fix.asp?isid=44677&prog=1294820935&printer=1
Hope that helps.........
I HAVE A VISTA 'HP' PAVILION LAPTOP. I HAVE JUST PURCHASED YOUR 'PRINTMASTER' PLATINUM VERSION 18. I HAVE BEEN UNABLE TO LOAD IT ON MY COMPUTER. I HAVE MISPLACED THE DIRECTIONS THAT CAME WITH THE...
Check this link for the step by step way in installing this software but this is for 'PRINTMASTER' PLATINUM VERSION 17 but dont worry its just have the same procedure in installing the 'PRINTMASTER' PLATINUM VERSION 18, this is the link
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
