SOURCE: Lowrance LMS522c transducer
Probably not. Usually the transducer is made specifically for the head unit it is designed for. More often than not, transducers are not interchangeable, particularly across brands. Also, for best results, you really want to install the transducer that came with your new lowrance. That will give you the best results and sonar clarity.
Hope that helps!
Please rate my solution on FixYa!
SOURCE: lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth
finder unit. It accepts the two pin lead from the transducer and send
the depth reading to the dashboard display via the 6-pin connector.
There is also a three wire harness (red/blk/wht) that connects to a
power supply.
The reason I know all this is my depth finder
fried a couple years ago so I removed the Lowrance LSM-1 from the boat
in order to find a replacement. Unfortunately, this was an OEM part
that is not available from Four Winns or any aftermarket source.
Probably your best bet is to look in a boat salvage yard or purchase an
aftermarket depth finder.
SOURCE: How does my Lowrance HDS-5
To connect a LRA 2400 to a Lowrance HDS-5 sounder/chartplotter, you can run an ethernet RJ45 cable from your Radar Processing box to the HDS-5 unit. You will need an adaptor cable for the RJ 45 cable to hook into the HDS-5 head unit. This is part no 000-0127-56.
As for the different transducer pinouts, I am not sure what transducer you have now so I cannot say if there is any kind of converter plug available, however, the HDS-5 units do seem to run best using the transducers that are made for them. Your best option may be to buy the transducer that is made for them, and this will directly connect to the display unit.
Hope that helps!
