What engine?
what country USA
gas or diesel
3.7 liter gas, usa
it primes at key on. (fuel rail pressure told you that)
sounds to me the barking up wrong tree?
its not a bad pump, its EFI issues
no symptoms stated, so , no help, can there be.'
no crank?
or my guess
no start?
starts for 2 seconds dies (asd drop)
or 2 second run, and then see IMMO lamp glowing (SKIS)
or will not run at all,even 1second/
scan it yet after first checking (test) fuses.>?
always at the least post what engines there
10x that if its an engine problem.........
Check for blown fuel pump fuse
As Bogdan suggested, check fuel filter- dirty or plugged
Place a fuel pressure gauge on the fuel rail, check pressure
defective fuel sensor solenoid? Lack of electrical signal?
Bad mass air flow sensor?
Fuel injectors energized?
Fuel filter did you replaced?a Battery is OK.
