There are three different transfer case's ! Which of these does your olds have ?
Transfer Case - NVG 136-NP4 (One Speed Automatic)
Transfer Case - NVG 233-NP1 (Two Speed Selectable)
Transfer Case - NVG 236 (Two Speed Automatic)
All three have an electronic control module ! When the light is on DTC'S are stored in the transfer case shift control module .
SERVICE indicator (AWD/4WD) lamp
The SERVICE indicator (AWD/4WD) lamp is an integral part of the instrument cluster and cannot be serviced separately. This lamp is used to inform the driver of the vehicle of malfunctions within the automatic transfer case (ATC) system. The SERVICE indicator (AWD/4WD) lamp is controlled by the transfer case shift control module via a Class 2 serial data message.
There are three speed sensors on the Automatic Transfer Case (ATC), two on the rear output shaft and one on the front output shaft. Each speed sensor is a Permanent Magnet (PM) generator. The PM generator produces a pulsing AC voltage. The AC voltage level and number of pulses increases as speed increases.
Vehicle Speed Sensor
One of the two speed sensors on the rear output shaft is the vehicle speed sensor (VSS). It is an input to the vehicle control module (VCM). The VCM sends this information to the transfer case shift control module via the Class 2 Serial Data bus.
Rear Propshaft Speed Sensor
The transfer case shift control module converts the pulsating AC voltage from the rear propshaft speed sensor to a Rear Propshaft Speed in RPMs to be used for calculations. The Rear Propshaft Speed can be displayed with a scan tool.
Front Propshaft Speed Sensor
The transfer case shift control module converts the pulsating AC voltage from the front propshaft speed sensor to Front Propshaft Speed in RPM to be used for calculations, and to monitor the difference between the front and rear propshaft sensor speed. It is also used in the AUTO 4WD mode of operation to determine the amount of slip and the percent of torque to apply to the front axle. The Front Propshaft Speed can be displayed with a scan tool.
Transfer Case Encoder Motor
The transfer case encoder motor is a permanent magnet D.C. motor and gear reduction assembly. The encoder motor is controlled with a Pulse Width Modulated (PWM) signal provided by the transfer case shift control module. It is located on the left hand side (drivers side) of the transfer case. When activated it turns the sector shaft of the transfer case to shift the transfer case. This circuit consists of a power supply relay (Motor Feed A circuit ) that supplies voltage to the motor. The Motor Control B circuit is a PWM driver that varies the duty cycle to control the amount of current through the motor to ground.
There are a number of codes that can set .
DTC C0300 Rear Speed Sensor Malfunction
DTC C0305 Front Speed Sensor Malfunction
DTC C0308 Motor A/B Circuit Low
DTC C0309 Motor A/B Circuit High
DTC C0310 Motor A/B Circuit Open
DTC C0315 Motor Ground Circuit Open
DTC C0374 General System Malfunction
DTC C0376 Front/Rear Shaft Speed Mismatch
DTC C0550 ECU Malfunction
DTC C0611 VIN Information Error
You don't want to just start replacing parts , that could cost $$$$$$ . You could check connections at all the sensors an the control module , but other then that ,well . Your best bet , take it to a qualified repair shop .
SOURCE: 2000 oldsmobile Intrigue V6
This could be a # of problems but try these: Remove gas cap and carefully inspect it and the fuel filler neck for small cracks and/or distortion/dirt. Under the hood there is a small green cap which is the test port for the evap system, remove it and check the schrader valve to be sure its tight ( left hand threads!!!). Check all hoses attached to this for cracks/breaks.Other than this a diagnostic will have to be ran with a smoke machine to pin point leaks or valve/switch/solenoid/canister failure.
SOURCE: service engine soon light comes on , anti lock & track light off
could be anything dealing with abs system...more than likely tho it means you have a bad wheel bearing/hub...least this was the problem on my alero when this happend
SOURCE: Service Engine Soon light comes on during a long,
I would check your air filter and then replace the MAF. It sounds like there might be an ongoing issue with the unit and may predict a failure soon.
SOURCE: can i disconnect the smart track system on this
the smarttrak runs off of a atc fuse under the hood which engages the transfer case yes it is possible
SOURCE: i have a 1998 oldsmobile
it needs servicing, take it to amco transmitions or the dealer that will garanty the work
