you can solve your problem easily,your uim card which is rejected by sim :firstly your uim card insert correctly or not secondly your sim card placed correctly or not if not both you insert the card correctly otherwise your must be phone off because sometimes phone hanged.
You have 2 choices 1 take your battery out and reinstall it 2 take to the shop and give them a real hard time you probably can get something for free especially if there are other costumers around
Good Moring, I have seen this behaviour in computers with virus (maleware) you can try the following 1)start your antivirus while log in safe mode and run a full scan if virus is found remove it and start windows normally run a full scan afterwards 2) if no antivirus is install, i would recomend you to reinstall the OS
remove the batteries from the remote, press the buttons (any) to dischrge any static that may have built up. replace the batteries and try again. Double check the batteries are inserted correctly, a common mistake that I have done myself infront of customers, make sure they have power also.
Nothing to worry about that,we can resolve your issue... I can tell u some steps to get it restart..if still issue persists kindly reply with ur mobile make and model no.
U can remove the battery and place it..switch on the mobile.
Have you tried removing the SD Card? If so, it's unlikely this has anything to do with the SD Card, it's probably coincidence. Try doing a hard power-off on the console by holding down the power button until the orange light on it turns red. Give it a few seconds then press the button to turn the system back on and see if it works.
