Cars & Trucks Logo
Gabriela Herrera Rubio Posted on Jan 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the largest continent in land area - Cars & Trucks
Bill Boyd
Level 3:
Top Expert:
  • Cars & Trucks Master 53,816 Answers
  • Posted on Jan 13, 2017
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951439
Points
172802
ASIA
a continent is one very large landmass on earth generally identified by convention rather than any strict criteria,up to seven regions are commonly regarded as continents --ordered form largest to smallest asia-africa-north america- south america, antarctica-europe --australia
Diagram 3 cylinder head timing
huh?
get the FSM, (buy one)
or got alldata.com and read. its all there......
be sure to know series # of LC and which of 6 engines used.
LC has the largest selections of engines ever put on one model car.
it Gobsmacks me.. that fact.. world wide.
1helpful
Clutch slipping on 1997 automayic land cruiser
check for oil leak around clutch area before replacing clutch.
1helpful
5helpful
2answers
2001 land rover discovery II locate fuel filter and fuel pump
for Land Rover Discovery 1999-2004 no more external Fuel Filter serviceable anymore...it's a built-in part with the fuel pump. so if you want to change the filter then change the whole fuel PUMP.
I own a 2000 land rover discovery ii and the rear brake lights are alway on when the key is in the ignitiion swithc or the car is running?
brake light switch is faulty should be in the area of brake pedal just disconeect switch if lights go out you have your problem
2answers
The check light is continously shown ON
Remove the terminal head from the battery if only you run a scan and there seem not to be any issue or code reported.
But I strongly recommend the scan.
Rate this solution.
2answers
Looking for the bell housing area on a 1998 land rover discovery
The Bell housing is the cover of your flywheel---it's attached between the engine and transmission and is shaped like a bell.
I opened my 04 discovery with one key, when I started it a little while later I did it with the spare key the car started but the horn sounded continously it only stopped when I inserted the first key in...
Your spare key probably isn't programmed for the car. Ford uses a stupid chip in the keys. I have the same issue with my Explorer. You have to buy a key from the dealer and have them program it for you. About $50-75. (Ford owns Land Rover, in case you were wondering)
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
