Ellen Domb Posted on Jan 12, 2017
How to set clock on Sherwood CRD-303 - Sherwood Audio Players & Recorders
Have just purchased model CRD 2196A but no manual supplied would like to copy manual if posssible?
no car /truck told posted to same./
w cant see or guess your car. sure diesel CRD
OMG CRD is radio not a car,
CD Stereo Dual Alarm Clock Radio
with Docking for iPod
google first hit finds it
https://images-na.ssl-images-amazon.com/images/G/01/00/00/05/00/21/30/500213070.pdf
ever google first?
1helpful
I have a zenith 5 device universal remote can i program it to opporate my RD-7500 Sherwood receiver. don't have original remote, what code can i try?
0374
This is the only one code, that I can find out to Sherwood TV. Anyway there might be more. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Irrespective of the brand name of the remote control, some other codes said for Sherwood TV might work.
Sherwood regulator is free flowing
Needs a seal rebuild kit.... They are simple to do, open the regulator up first and check that there isn't any salt or dirt inside
2005 DIAGNOSTIC ERROR CODE P0069, CRD ENGINE WONT
Are you traveling high ground like Rocky Mountain?
I will remove the ground cable for 4 minutes to reset all data in ECU.///clock and radio stations too : (
Let the ECU to relearn the local environment parameter.
Here's so info on how to prevent vapor lock
Ride with full tank of gas but NO TOP OFF.
Crack open gas cap carefully during rest stops to release / equalize gas tank pressure'
http://www.estes-park-information.com/vapor-lock.html
Good Luck
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
Arnie Burke
Arnie Burke
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
