Pyramid 1000W 2CH SUPER BLUE AMP Car Audio Amplifier Logo
Posted on Nov 20, 2007
Adding 6x9s to my citreon ax
Got a wiring block , bt am very unsure of what colour wire i need to wire the speakers in to .
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Nov 20, 2007
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
7395
Points
57
Can you be a little more specific??
2answers
Speakers
Could you specify the model of the Sanyo speakers?
Amplifier do not have sound. E-mail: [email protected]
You may have blown the inline fuses for output sound. Amps have alot of fuses under the hood. take the amp cover off and check all fuses are not blown / wire broke inside fuse. Some fuses are hidden under circuit boards on some amps, check everywhere possible to check all fuses. If all fuses are fine and no broken wires inside them, you may have loose connection where your speaker wire ports are inside the amp. Check they arent black or loose. if they black they are blown as there usually soldered (a silver colour)
1helpful
2answers
My 6x9s have stopped producing bass together
There is a short in your wiring somewhere, unfortunately, it would be impossible for me to tell you where it's at. The best advice I could give you is to start at the speakers and work your way back. Hope this helps and good luck!
How to replace rear speakers in a daewoo leganza 2002
Open your boot, disconnect the wires from the terminals, unscrew the speaker. Remove the speakers. If you're upgrading from 6x6s to 6x9s and the whole is too small you will need to mount them on spacers. Screw the new speakers down from inside the car. You will need to wire the wires in the same configuration as your old speakers.
Can a rf 201s amp push 4-6x9s and 4-104s door speakers
Hello jon_jonmay,
Wiring 4 speakers to each of 2 channels, you will need to wire them series-parallel and run them at 4 ohms. If you wire all 4 parallel, the load will be 1 ohm and the amp is only stable down to 2 ohms.
According to your manual, the 201s will deliver 50 watts into each channel at 4 ohms . So it will be supplying about 12.5 watts per speaker which is about what you get with the average factory radio. They will work OK, but they're not going to be very loud.
Hope this helps.
6x9 hook up
yes conect the wire to the new speakers and it has to work
Speaker installment
I would run a 250-500 watt 2 channel high input capable amp.  run the original wires to the orginal speakers and jump off the original wires to the amp to push the secondary 6X9's you have.  So my understanding is.  you want the 4 original speakers and subs and add 2 additional speakers making 6 speakers not uncluding subs..
Head units care barely push 4 decent normal size speaker.  Usually they are 30-55watt per channel.  If you have 2 non sub speakers that are 250 watt max.. that's 500 total but don't push the amp all the way...start with it at 1/4 and listen to your stereo at a higher than nominal volume slowly turning up the amp.
James Mac
3helpful
2answers
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Help me!!!! i have fitted this sub & amp but how do i fit a 2nd amp for speakers
youll need distribution blocks for second amp.this is the basic solution though.other things like wire guages,amp power and crossover settings need to be considered.
Need Wiring Help
how do u have everything wired for the amp and speakers?
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
