SOURCE: service engine soon light on a 2000 cadillac seville
The service engine soon light indicates you have a problem with the engine management system.The only way to get it to stay off is to lacate and repair whatever is not working correctly. Requires very specialized equipment. Take it to your mechanic.
SOURCE: replace power steering pump and lines 1992 cadillac seville sts
you need to have a pulley puller to get the pulley off if you don't have one most auto zone part stores have a loan a tool program and they can help you with that on most powersteering pumps the high pressure line will be a fitting or bolt on and the return line is usually just a squeeze clamp hope this helps good luck
SOURCE: How do I change my rear brakes on my 2000 Cadillac
you will need to remove the parking brake cable from the caliper then remove the lower slide pin bolt, flip the caliper up and pull out the old pads and install the new ones. You should get the rotors machined for the best braking performance or replace them.
SOURCE: reset change break pads light
With a code scanner or I do beleive it will clear after 100 starts.
SOURCE: How do I R&R front motor mounts on 2000 cadillac sts
Very easy, just remove front tires and unbolt, BUT I doubt you are asking right question. Not mounts, but mount in dead front center is problem. There are 4 mounts, transmission center back, left center and right center and front center. That takes full torque of motor and heat from exhaust. GM has a shield for exhaust.
