disconnect battery negertive terminal
undo and remove the 10mm (spanner size) nut and disconnect the solenoid wire
undo and remove the 13mm (spanner size) nut and disconnect the main starter lead and the alternator wiring
undo and remove the 13mm (spanner size) bolt through the lower mounting point on the starter, this has an earth lead on it, push the lead to one side
undo the top starter bolt (same as lower bolt) and remove the starter from the engine. The top bolt can't be removed from the starter with it in place, and it can't be fitted after you've put the motor back either so don't forget it!
Fig. Remove the starter motor and bolts
