Microwave Ovens Logo
F
Frank Lock Posted on Nov 16, 2016
I have a "continuous" humming sounding when units are heating. The sound is very loud
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 05, 2008
SOURCE: Microwave made a loud pop,won't
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
tiway1
Tim martin
  • 100 Answers
  • Posted on Sep 06, 2008
SOURCE: Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Anonymous
  • 93 Answers
  • Posted on Aug 29, 2009
SOURCE: GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Anonymous
  • 403 Answers
  • Posted on Feb 06, 2011
SOURCE: Runs but has loud humming sound. Does not heat.
The diode that connects to the capacitor needs to be replaced. Once its replaced microwave will begin to heat again. (If it wasn't heating and wasn't making a humming noise, then your magnetron would need to be replaced). If you are thinking of doing it yourself and need instructions, i'll be glad to help.
Anonymous
  • 43501 Answers
  • Posted on Feb 25, 2011
SOURCE: runs normally, but makes loud
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
2answers
MY ROPER MICROWAVE NOT GETTING HOT
Hi and welcome to FixYa, I am Kelly
When everything but the heat works there are 2 common components that fail. The high voltge capacitor or the high voltage diode. In rare cases the magnetron fails because the oscillator in the top of the magnetron sticks. When the oscillator sticks the magnetron makes a LOUD humming sound and you do not get heat. However.... a open diode or shorted capacitor will make the exact same sound briefly before the main in line / internal fuse fails.
The capacitor and diode are items 4 and 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504310&diagram_id=28243249#d28243249
NOTE: Before doing ANY maintenence you must hold an plastic handle screwdriver back on the handle and ground the capacitor terminals at least 3 times. (Just in case it has not failed.)
Failure to do so will ruin your day and pass along one heck of a shock.
To check the diode you must disconnect one terminal first. The read it with a meter. Reverse the leads and check continuity again. It should read continuity in ONE direction / polarity only. Id should NOT read open both ways or shorted both ways.
To check the capacitor you have to remove all the terminals from ONE side of the capacitor terminals. With the meter on R X 10,000 probe the 2 terminals. You should see a brief jump in resistaqnce and then the meter drifts to infinty. Reverse the leads and do this again. You must get the same jump in resistance and then the meter drifts to infinity. If it does not do this it has failed and must be replaced.
If both the diode and the capacitor pass the checks above the next step is to check the magnetron for continuity across the 2 terminals. It must read continuity. Even if this test passes the oscillator can be stuck and it will not heat. (Again if it is stuck it will make a LOUD humming noise.) It is not repairable.
I suspect you either have a bad diode (most probable cause) or bad capacitor (2nd most probable cause).
Thanks for choosing FixYa,
Kelly
GE JE1860WH 04 microwave runs but want heat and it hums loudly.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
heatman101
3helpful
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
It makes a sound when on and smells like burning
If it's an arcing sound, there may be grease or food particles on or behind the waveguide cover or in the area of the turntable motor.
Otherwise, it's likely to be a failing high voltage part:
- A sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound. Usually it will not heat is this is the case.
- A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but if this were the case, it would not heat.
- Sometimes a high voltage transformer will cause a loud hum and burning smell, too.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your specific symptoms.
Let us know which of the examples we gave seems to be closest to the sound you're experiencing.
3helpful
3helpful
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
Oven does not heat and makes loud, continuous "hum" when turned on and related to turning of oven table.
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
KitchenAid KHHS179lss, fried magnitron?
If your magnetron was shorted, the unit would not heat at all.
The sound of a shorted magnetron is usually a loud hum-- but no or very little smell and no smoke.
Components in the High Voltage section -capacitor, diode- give problems if they short out.
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
