Feb 15, 2008 - The i765 is the latest and greatest entry from Cambridge's well-regarded line of stereo clock tabletop radios. The new model also boasts a slot- ...
Rating: 3.5 · ‎Review by Steve Guttenberg
See my answer to cd740 sound cutting out. Fuse is inside near the transformer. You'll need to disassemble. There is a good write up for a question about getting to the faceplate. Briefly, there is a sub base that has screws hidden behind the rubber feet pads which peel off easily. The front speaker grills PPP off easily and it hides some screws. The rear plate also has to come off. Check those other questions, the answers will help.
I believe the problem is either a faulty light sensor the unit has to dim the display when the lights dim since it was designed for bedroom use with alrms and snooze button. or it is simply a failure in the circuit that drives the LCDs. Mine has been dim for a long time but I can still see just enough to adjust the sound settings. I tune and set stations by sound. so the display has not been an issue since we do not use it for a clock or alarm. I doubt there is a fix for the dim display.
Mine is dim also. Apparently sending it in for repair is not an option.
Unfortunately, the CD740 radio has reached end of service life.
Parts are no longer available & we cannot repair them. We apologize
for any inconvenience. If you need further assistance, please call us
at -800-367-4434, Monday - Friday 9AM to 6PM central time.
-- Best Regards,
After my post, I found that someone had had a similar problem and had solved it by unplugging the radio cd from the mains, then plugging it back in and holding down the eject button when switching back on. This reset the CD drive and all is now well.
Thank you
I just had the same problem and called tech support (800) FOR HIFI at Cambridge Soundworks for help. All you have to do is unplug the radio for 30 minutes and then reconnect - kind of like rebooting a computer.
