SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
SOURCE: I have a frigidaire sisde
Success!! I just bought a Frigidaire Gallery series side by side model # GLHS39EPJW0, in Canada. My temp readout was in F and I would like Celcius. The hidden button between the readouts I could feel, but it didn't work. However, holding the Fridge readout "up" and then pushing the Freezer readout "up" three times switched me from F to C on the fridge side. I repeated this but pushed the freezer "up" twice and the freezer readout changed to C. Thanks for the info - it helped out when Frigidaire couldn't.
Eden in Canada
SOURCE: refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
SOURCE: MY traulsen 20010 Microprocesor reads 34 degrees
Your temp sensor is most likely the trouble. It is reading a false temp so it keeps the unit running trying to reach set temp. I would go there first as it is much cheaper than replacing the controller.
SOURCE: how to set temp on traulsen refr rth132dut-hhs commercial
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35748%20G-Manual%20(3-09).pdf
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35748%20Rev%201004.PDF
Check this web sites. It has manuals for your unit based on when it was build.
Let me know if I can be of any further help,.
