Yes, I know that would seem to be an obvious solution, but they don't seem to have the model's service manual online for downloading. Thanks for your thoughts.
You can't post conmments that contain an email address.
NO but you can change the temp sensor(switch)for one that operates at the temps you want.....(or get the neighbors to buy in bulk and use your freezer.....)
You can use R134a compressors with the Poly oil in them and use R12 or R134a (flush the remaining old mineral oil out of the system first). Match your BTU requirements.
may be you have problem with the Evaporator fan motor not running, defrost heater, defrost timer, open gap on door gasket and bad thermostat (cold control), it may kept the compressor constantly running. Good luck.
I'm not intently familiar with this particular brand, but here's some ideas to check. If the thermostat sticks on, the freezer coils can freeze, blocking air flow and jamming circulation fan. This will cause the temp in freezer compartment to rise. When the ice on the coils thaw, the compartment starts to cool again, but the cycle will continue. Another thought is if this unit has a defrost timer that could be defective. Without seeing the unit, it's hard to determine the exact cause.
Hope this helps.
I called Traulsen with your model and serial # and was able to ID the manufacture date, Oct 4, 1989.
We specialize in cooler/freezer gaskets. We also sell refrigeration hardware & accessories. We can get many Traulsen OEM parts below list price. We'd be happy to help you locate the parts you need.
Shoot us an email to [email protected] or call toll free at 855-288-2259
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
