SOURCE: Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
SOURCE: door ajar alarm ringing and refridgerator not cooling enough
This could be a defective thermistor telling the fridge that the evaporator fan is frozen up with ice. But if you are lucky like me it is a defective door switch, telling the fridge that the door is open when in fact it is closed. The fan sending cold air from the freezer section to the refrigerator section turns off when the door is open, so a defective door switch can keep that fan turned off all the time. Push the buttons on the door switch to see if the lights go off in the freezer and refrigerator. If not, use a knife or screwdriver to pry out the switch and unplug it. Then you should hear the fan turn on, and the refrigerator start cooling. Good luck! genetuck PS....my light was not coming on at all, and I had to unplug the refrigerator for five minutes, then plug it in to get the light to work. I just discovered the switch was defective, and don't know yet if there will be any future problems with the light.
Business Hours:
Monday - Thursday: 8:30 - 5:00 EST
Friday: 8:30 - 4:00 EST
By Phone:
General office: 419-425-8627s
Sales: 866-641-3309
Consumer help line: 800-263-2629
By Fax:
General office: 419-425-5052
Sales dept: 419-425-8629
By Mail:
Danby Products Inc.
PO Box 669
Findlay, OH 45840
By Email:
Consumer inquiries: [email protected]
Dealer inquiries: [email protected]
