Question about Danby DKC645BLS Compact Beverage Cooler
I HAVE DANBY KEGERATOR THAT IS BEEPING AND SHOWS EE IN THE TEMP BOX. WHATS THE PROBLEM? CAN I GET PARTS
  • Danby Master
  • 3,740 Answers
This is from another source and will post the link but wanted to pass it along so you would have the info.
the EE is saying that it is not getting the proper signal from the sensor inside the kegger. You need to check the wiring from the sensor inside the kegger that goes to the board behind the display. If that looks good you need to take off the top and check the wiring. If that is all okay your problem is the board behind the pushpad. That you willl have to get from Danby. Runs about $35.
Read more: http://www.justanswer.com/questions/2ebpq-my-danby-keager-dkc645bls-has-an-error-message-ee-how-to-fix#ixzz0gZzN2VOZ
If you don't have a users manual you can get one here:
http://www.danby.ca/cms/uploads/products/en_manual/DKC645BLS_EOM.pdf
The Danby site www.damby.com does not list parts
Phone 1-800-263-2629 to find a service / parts provider.
Posted on Feb 25, 2010
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Tip
Danby Kegerators
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded. A lot of the errors are caused by a loose connection. There are 3 screws that hold the table top down, once you get the table top up you'll see the connectors to the boards and sensor, just start removing the connectors, straighten the pins and reinsert them. Also if you ever have an issue with the fan motor, that part is no longer used on these keg coolers, the replacement board assm no longer has a connection area for the fan so the fan can be disconnected if it causes you issues. Another handy trick is to put turtle wax over the touch pad were you select the temperature, then that way the spilled beer will roll off the touch pad instead of ruining it :-)
on Jun 20, 2012 | Refrigerators
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
Not cold enough
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded sometimes the error can be solved by simply disconnecting the molex plugs from the boards, straighting out the pins and reinstalling
Sep 17, 2010 | Danby DKC645BLS Compact Beverage Cooler
I plug it in it beeps and shows a ee code
I just plugged my new one in and am having the same problem too. I was planning on calling Danby tomorrow. Did you figure out what it was?
May 27, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Danby DKC645BLS Compact Beverage Cooler Logo
4,726 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
