The filter has what almost looks like a fan blade on one side and the other side looks like it should snap onto something.
SOURCE: belt
Turn vac over, take out 4 to 5 screws and the top cover will come off. The belt is a cogged belt #72393 and goes between the brush roll motor and the brush roll.
SOURCE: My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
SOURCE: Eureka Bagless Widetrack, The Boss, Vacume, model 5893
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis. It is Part #27871.
