SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
SOURCE: I can not figure out
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
SOURCE: the right dial won't work.
I have the same problem with the dials. The best solution I can offer there is to pop the dial off using a thin tool and then putting it back in place with the grooves aligned. As for the ipod not working, the ihome should have came with fittings that sit where the ipod goes to make that connection snug. If you have lost them I'm sure you could find one online.
SOURCE: Lost the manual for my nexplay alarm clock/ipod dock
Setting the Clock:
1. Press the SET Button 3 times until all digits for the main clock are flashing.
2. Press Skip forward and back to change the hour and Volume up and down to change the minutes.
3. Press the set button once to save.
