Gulf Stream 2009 Euro Touring Cruiser 5290 Logo
y
yvon Posted on Aug 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2009 Euro touring as no power going to the halftime oven and I would like to know where is the wire coming from Wirering schematic electrical diagram
Halftime oven plug as no power and I cannot see where the wire is coming from front or back
DROPNDEAL
Level 3:
Top Expert:
  • Gulf Stream Master 2,931 Answers
  • Posted on Feb 05, 2018
DROPNDEAL
Gulf Stream Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932735
Points
21770
Contact your local retailer directly or online here:
1976 Dodge Apollo Motorhome. I need a wiring schematic please?
Question edited for clarity and dyslexic typos.
Question moved from Household electrics.
https://www.google.com/search?q=1976+Dodge+Apollo+Motorhome+wiring+schematic
Jul 26, 2022 • RVs
1helpful
2answers
2006 Prowler Camper Electrical Issue
I tidied up the question a bit :>)
You have a regulator / control box issue. You have two systems;
You have a towable trailer. A vehicle battery in it that gets charged as you drive from a cable in the plug. When you stop that battery ceases to charge. No power in. If you use lights or use an inverter to take the 12 volts and turn it into 110 volts to run appliances, the battery is draining until it becomes flat.
So,..... we bring mains power hook up into the equation.
The mains power should run all your mains 110 volt appliances and provide a trickle charge to keep that battery topped up, but the battery is NOT actually being used, just being charged.
So that is the theory, somewhere you have a piece in the jigsaw puzzle that isn't working. You have a controller box that isn't doing what it is supposed to do. I don't know the trailer, you probably need a dealer that does. Fleetwood went bankrupt in 2009.
If you Google
fleetwood prowler electrical schematic diagram
There are wiring diagrams. I see a battery disconnect solenoid, but all of the dot .it Italian and .fr French sites as scam sites. There are also RV Groups that might be more help than me.
This might help
https://axleaddict.com/rvs/RV-Electrical-Tips-and-Reference-Data
Hope the information helps. A short term solution would be a full size batter charger charging your battery overnight after disconnecting it from the negative lead so just the battery is being topped up. You don't need an inverter if you have mains hook up.
Mar 04, 2021 • RVs
I have had to replace several of the GFI outlets in my 1993 class A. They would trip with nothing plugged in. Do they go bad over time or do I have a problem?
They do not go bad for no reason, You have a problem, something is causing the outlets to trip. You will have to isolate each individually to check to include where the power comes from at the breakers. It may be as simple as a wire coming loose but the GFCI is doing its job to make sure your unit does not have an electrical short to cause a fire. The best thing to do is kill the power to this outlets, then disconnect all of the outlets making sure to use a wire nut or electrical tape to protect from arc flash. One at a time, connect an outlet and turn the power on to check. It you have had an issue with an appliance or power surge, the GFCI may have been damaged.
Mar 10, 2018 • RVs
1helpful
Thermostat has no 12 DCV power. I need a wiring diagram to find where to power comes from.
go to a jayco service center and ask for a schematics diagram as they will be the only place to get it from
Aug 20, 2016 • RVs
2answers
Looking for wiring diagram for 2009 four winds hurricane motorhome
Try the manufacturer first. Most have schematics you can download off the Internet or they will mail it ot you. No luck, google it. 90% of the time you can find one if you are persistent.
1helpful
2answers
Slide and Awning Electric problems
i have seen a meter lie, it shows a good circuit, but when a load is applied the circuit breaks, try a test light to see if the breakers hold
2answers
Electrc trailer brake wiring schematic
Not knowing the year or model makes this impossible to answer.
Dec 28, 2013 • RVs
Top Gulf Stream RVs Experts
David Spradling
David Spradling
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Gulf Stream RVs Expert? Answer questions, earn points and help others
