SOURCE: low battery in Uniden cordless phone.
Unless you have one of the water proof phones, hold the handset with the keypad facing your palm, and the top facing your body. Press very firmly at the endention on the battery cover pushing it in a little and down at the same time. Sometimes they are pretty tight but it should come off with a little effort. If it is a waterproof phone, there are four small screws at the corners of the battery cover that will need to come out before the cover will come off, be very carefull as the screw heads are fairly easy to strip and if that happens it is almost impossible to put it back together and still have it waterproof.
SOURCE: Cordless phone battery
Cant find that exact code, but i would have thought it was here - GE cordless phone batteries
SOURCE: I have a Telstra 6200a cordless phone. I can
0000 is da phone code........first switch on ur phone and then go to setting and just reset them
SOURCE: my telstra 8100 cordless phone keeps showing the w...
Place the telstra 8100 handset in the charger. Call any number while the handset is in the charger and it should dial out - you can hear the dial tone now. Take the handset out of the charger and you should be able to call normally.
cheers Matt
SOURCE: New batteries were installed into
Since phone is dead, then it means the battery cell is weak. You need to boost the battery. Once the battery is boosted, you can now continue charging it and it would charge.
The cell in new batteries are sometimes very weak because it might have been in stock for a very long time. When a battery as not been used for a long time, the cell gets weak. Probably, the new batteries you bought has been a stock for a long period of time.
Get a desktop charger, use it to charge the batteries and about 6 hours or more and put it back into the phone..... I believe the phone should turn this time around, then you can continue to charge it with your phone's charger.
Below is are pictures of what a desktop charger looks like;
Good luck.
