SOURCE: Leakage from eureka deep steam carpet claeaner
You will just have to take it apart to see if a hose is loose, came off, or is cracked.
SOURCE: No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
SOURCE: eureka capture model 8803 type AVV...runs for 10
This could be a few issues. First it could be the thremel swith located inside, or it could be the carbon brushes also located inside. If you are a do it yourselfer you can purchess the carbon brushes from any vacuum repair shop. The thermal switch should be tested before replacing "thus- you shoud have a local repair shop look at" I would find one that offers free estimates so they can diog. the problem. then buy the part and start the fun part. Saving big $$$$$$
SOURCE: A BELT FOR THE VACCUM CLEANER (EUREKA)
Here's a link to this exact belt for your vacuum cleaner on our website:
http://www.govacuum.com/1555.html
I hope this information helped you! Please be sure to rate this helpful if it did so other Fixya users with this vacuum can easily find this belt.
Thanks,
Chris J.
GoVacuum.com
SOURCE: bag model for Eureka Mega Boss 4460 type E
The model 4460 is for a Victory model which uses Eureka Type AA bags
They can be found at http://www.totalvac.com/eureka_aa_bags.html
