1998 Mercury Mountaineer Logo
Posted on Jul 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I could not find the speed sensor location on my 98 mercury mountaineer. Where is it?
  • Anonymous May 11, 2010
    can't remember, but look on the trans tailshaft, transfer case or the rear differential...usually it's in one of those three places.
  • Anonymous Jun 22, 2013
    not on this one for some reason looked at all of them
Anonymous
Level 2:
  • Expert 72 Answers
  • Posted on Jul 18, 2009
Anonymous
Expert
Level 2:
Answers
72
Questions
0
Helped
40582
Points
270
The Output Shaft Speed Sensor is located at the lefthand, (sitting in the driver's seat) rear of the transmission.
2answers
2010 Mercury Mountaineer 4.0 Liter, V6 engine. Where is the Camshaft Position Sensor on it please?
Sensor marked number 3
Ford 4.0L SOHC V6 Engine Sensor Locations
TroubleCodes.net https://www.troublecodes.net > sensors > ford-4-0l-soh...
Fuel injectors (located underneath the intake manifold) · Mass airflow sensor (MAF) · Camshaft position sensors (CMP) (located at the front of the driver side ...
Same engine
Location removal and installition of transmission speed sensor
Hi Anonymous, the link below is a youtube video showing how to replace a speed sensor on a 2000 mercury villager, I hope this motor and your motor are similar, Good luck and CHEERS..
How to replace speed sensor on 2000 Mercury Villager Nissan Quest
Where is fuel rail pressure sensor high input located on a mercury mountaineer
If you are talking about a trouble code for the pressure sensor, the sensor may be telling the computer the fuel pressure is too high. The sensor is mounted in the fuel rail on the engine.
1helpful
98 Mountaineer shifts back and forth from 3rd to overdrive...like it doesn't know what gear to hang it..it shifts hard at times...anybody got a answer for this..??? Thanks,
You need to replace either the vehicle speed sensor depending on your mountaineer it could have two, or transmission ranger sensor.
2helpful
98 mountaineer is stuck in 4 wheel drive, how do I fix this?
if you go reverse for a while on a 10-15 speed...it should unlock...
good luck!
2answers
1helpful
Can anyone help with an intermittent starting issue with a '98 mercury mountaineer?
If the motor turns over, but not start. Have the "crank shaft sensor" checked/replaced Ford part# 184768 $27.98 parts $230.00 labor). I chased this problem for several years. The crank sensor finally failed completely and the mechanic was able to find the problem.
Good luck
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
