This oven gets extremely hot and it makes the electrical outlet that it is plugged into very warm as well. We have started unplugging the unit unless it is in use. Sometimes, it will even trip our breaker if it is in use. The cord gets very warm. It is still under warranty, should we return the unit?
SOURCE: Why does this toaster oven cord gets hot?
I would make sure the cord doesn't get too close to the back of the oven. Make sure it has room between the oven and wall and isn't trapped under it or direct heat.
I had my cord get squeezed between the machine and the wall and my cord melted.
SOURCE: KitchenAid toaster oven Mod# KC010058
Using this solution:
the problem is the current overload switch is faulty, the bi metal spring should heat up and break contact with the pin. this does not happen, the heat builds up and the solder holding the pin in place melts away and the pin falls down. this breaks the contact and no electrical current will result.
I opened the overload switch and put a solder drop on the ping. Works like a charm!
Thanks FixYa!!
SOURCE: my ge toaster oven has a short circuit. It trips
I could not reach the electronics to use a multimeter. Had to dis assemble 80% of the oven to even clean the electronics. Lots of crumbs.I used a 1" soft paint brush to clean. Tried the oven ON switch one more time.It worked!
No Problem - But re assembly was a nightmare.
I should have used my bicycle air pump.
