I am unable to get my heat/air conditioning to blow out either hot air or cold air. I feel the warm and cold air, it seems there is a fan not working. Can you please help me with a solution.
You should check to see if the a/c heater fan motor has power first. If it does, then the motor is most likely bad. If there is no power there then the fan relay, usually mounted on the firewall in engine compartment may be the culprit. They have been known to get very hot and start to melt internally, causing failure of power to the fan motor. I have replaced three of these relays and finally had to replace the socket connector as well.
You need to replace the blower motor, Im not %100 on the location of the one in a 97 pontiac mini van, but they are generally located just above the floorboard, under the dash on the passenger side of the vehicle.
GOOD LUCK
