With new belts, the main belt slides off the common pulley. This pulley is loose. How do you get to it?
I'm not sure what you mean by "Common Pulley". There is a flat belt that goes from the motor shaft to the big round pulley on the transmission. There is also a "V" belt that goes from the transmission to the brush roll. You have to be careful how you install the "V" belt because it has a pulley that takes the slack out of the belt when you pull the handle back if you have the lever in "Carpet" position. The belt does not get tight until you pull the handle back which leads many people to believe the belt is too long or the pulley is not working properly.
