Sport & Outdoor - Others Logo
T
TNCraigie Posted on May 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set up my 2 room Campmate tent?
Set up instructions
Jerry Kramer
Level 3:
  • Master 3,933 Answers
  • Posted on May 11, 2016
Jerry Kramer
Master
Level 3:
Answers
3933
Questions
Helped
882425
Points
12076
Lay it out flat. Steak all of the corners down. Firm but not to tight. put your shock rods together and string them through the loops made for them on the top the tent and secure them at the corners, probably a pin on the corners that need to be inserted in the shock rod pole bottom. Once you have them all up then you can put up the rain fly. Use the shock rods to do this and place the canopy over the top and secure the elastic cords to the corners and you are done.
Pitching instructions for a great outdoors executive 320 tent and sunroom
This is a duplicate of a previously asked question on FIXYA from 2012, where an exact set of instructions could not be found, but two proposed answers were given.
For a similar but not the same tent, the scanned document still exists online:
https://drive.google.com/file/d/0B1SdA-vKLONwZ05vTGZKdF9BTzQ/view
https://www.fixya.com/support/t7407226-need_pitching_instructions
Quoting from FIXYA question from 2012
Wollocks
Jim,
these are the instructions I devised as I had no instructions either...
Great Outdoors Executive 320 tent
Two rooms plus a fully enclosable veranda.
(4.9m long x 4.3m wide x 2.4m high)
Main Tent Assembly :
Lay the tent out on the ground (making allowance for the slope of the ground, prevailing wind, general access, etc).
Peg down the main corners and centres of each wall, keeping the tent square and evenly tensioned. Peg down remaining loops.
Assemble two sets of side support poles. These have been numbered (from the front, looking towards the tent (ie, facing the veranda)) :
Left-hand side : L1, L2, L3, L4 & L5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports LF1 & LF2 and LB1 & LB2 (ie, 2 sets of poles 5 & 9).
Right-hand side : R1, R2, R3, R4 & R5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports RF1 & RF2 and RB1 & RB2 (ie, 2 sets of poles 5 & 9).
Place poles in the loops along the sides ensuring that the 4 brown loops (at each end of the sides) are looped behind the projecting studs (this ensures the sides don't slide into the centres.
Lift & tension one side, then the other.
Assemble the centre poles (numbered C1, C2, C3, C4, C5, C6 & C7 (corresponding to poles 12, 13, 8A, 24, 3, 4 & 8)).
Slide the centre poles through the centre of the tent. Use poles 14A & 15 to hold up the rear of the tent, poles 14A & A in the centre, & two further sets of 14A & 15, one set at the front of the tent & one set for the veranda. Tension by expanding the poles.
Assemble poles A, BE, C2, BE & A through the centre of the tent, clip onto ridge poles & tension. (Note : poles A should be inserted from the outside, through the elasticised holes before being inserted into poles BE).
Attach a guy rope to the rear of the tent (top of centre pole 15) & tension.
Veranda Assembly :
Assemble 4 sets of poles (10 & 30) & place in corners & centres of the veranda. Attach guy ropes & tension. Attach veranda walls (using Velcro strips).
Porch Assembly :
Select which side is to be an entrance. Unzip the window covering & use two poles (10 & 30) to lift it. Tension with 2 guy ropes on each pole.
hope the above helps.
Warwick Annear
[email protected]
Set up directions for wenzel swiss gear tent style 36288 also has HO5J30 on label
Hello -
I have found some instructions online with directions on assembling a Wenzel tent. However, none of them are clear is they are for the Swiss Gear tent style 36288.
See these instructions:
http://campingexpertguides.blogspot.com/2016/06/classic-wenzel-camping-tents-assembly.html
If you have not already done so, I suggest you contact the Wenzel Tent & Gear Co. directly and ask a Customer Service representative about the availability of assembly instructions for your Wenzel tent style. The company may hold instructions in the corporate archives which can be copied (for a fee) for you.
This is the link to the Wenzel Tent & Gear Co. Contact Us page:
https://wenzelco.com/contact-us/
If you choose to make a telephone call, I suggest you do so during weekday business hours (Mountain Time).
Best wishes.
2answers
Bought a used wenzel 8 person granite point 3 room family dome tent on ebay.how do I set it up or get instructions to set it up???
Here is a video of the set up of a similar Wenzel tent, yours should be about the same. Additionally you can contact Wenzel and give them the model number (sewn on a flap inside the door) and they will send you the manual.
I need instructions for 89034 17x15 moab
Instructions
  1. Select a flat camping area and clean the area of sticks and rocks. Remove the tent from the bag and spread out the tent body with the floor on the ground. Assemble the tent poles by connecting the attached sections at the ferrules. Set the poles on the ground and separate by size.
  2. Locate the three long sleeves on the tent body. One sleeve is horizontal over the screen room and the other two cross the main tent body to create an "X". Locate the three long poles and slide one through each sleeve. Place the corresponding pins in the end of the poles. The poles will flex and erect the tent body. This step is best attempted with two or more people.
  3. Attach the clips to the exposed sections of the tent poles. The clips are attached to the ten fabric and will add rigidity to the tent. Locate the next largest pole and insert it through the sleeve on the screen house. Locate the metal grommets where the screen room meets the main tent and place each end of the pole in a grommet.
  4. Locate the two smallest poles. These are for the side rooms. Insert one pole through each of the side room sleeves. Attach the ferrule of one steel pole to each end of the side room pole. Insert the corresponding pins in the end of the upright poles to support the side rooms.
  5. Pull on each end of the tent to ensure the floor is tight. Use a rock to pound stakes through the ground loops on the tent. Place the floor mat in front of the screen room door and use stakes to secure the mat to the ground.
  6. Place the fly on the tent and make adjustments until the shape of the fly matches the tent. The fly will only cover the top of the screen room and the entire body of the main tent. Locate the D-rings on the base of the tent and attach the fly hooks to the closest rings. This will tighten the fly to the tent body.
  7. Locate the guy ropes on the fly. Pull the ropes to the ground at an angle and pound stakes through the loops to anchor the tent to the ground.
Read more : http://www.ehow.com/how_8092535_directions-ridgeway-tent-kelty.html
Jul 23, 2015 • Baby Gear
6 person campmate tent
Looking for instruction for Camp mate Laurentian 6 Man Tent
6helpful
2answers
I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
Paul.
Square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
2answers
Need instructions for a col-1390 coleman tent?
The directions are on the actual tent bag. The trick to setting this tent up is to stake it down first. Then set up the center poles - you will need at least two people to do this. Once it is staked it will go up pretty fast.
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
