I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
Paul.
Jim, Two
rooms plus
a fully enclosable veranda. (4.9m long x 4.3m wide x 2.4m high) Main Tent Assembly : Lay
the tent out on the ground (making allowance for the slope of the
ground, prevailing wind, general access, etc). Peg down the main
corners and centres of each wall, keeping the tent square and evenly
tensioned. Peg down remaining loops. Assemble two sets of
side support poles. These have been numbered (from the front, looking
towards the tent (ie, facing the veranda)) : Left-hand
side : L1, L2, L3, L4 & L5 (corresponding to poles 1,
24, 3, 4 & 1). Add
front & rear supports LF1 & LF2 and LB1 & LB2 (ie, 2 sets
of poles 5 & 9). Right-hand
side : R1, R2, R3, R4 & R5 (corresponding to poles 1,
24, 3, 4 & 1). Add
front & rear supports RF1 & RF2 and RB1 & RB2 (ie, 2 sets
of poles 5 & 9). Place poles in the loops
along the sides ensuring that the 4 brown loops (at each end of the
sides) are looped behind the projecting studs (this ensures the sides
don't slide into the centres. Lift & tension one
side, then the other. Assemble
the centre poles (numbered C1, C2, C3, C4, C5, C6 & C7
(corresponding to poles 12,
13, 8A, 24, 3, 4 & 8)). Slide
the centre poles through the centre of the tent. Use poles 14A
& 15 to hold up
the rear of the tent, poles 14A
& A in the
centre, & two further sets of 14A
& 15, one set
at the front of the tent & one set for the veranda. Tension by
expanding the poles. Assemble
poles A, BE, C2, BE
& A through the
centre of the tent, clip onto ridge poles & tension. (Note :
poles A
should be inserted from the outside, through the elasticised holes
before being inserted into poles BE).
Attach
a guy rope to the rear of the tent (top of centre pole 15)
& tension. Veranda Assembly : Assemble 4 sets of poles (10 &
30) & place in corners & centres of the veranda. Attach
guy ropes & tension. Attach veranda walls (using Velcro strips). Porch Assembly : Select
which side is to be an entrance. Unzip the window covering & use
two poles (10 &
30) to lift it.
Tension with 2 guy ropes on each pole.
these are the instructions I devised as I had no instructions either...
Great Outdoors Executive 320 tent
hope the above helps.
Warwick Annear
[email protected]
