I went for a nap and decided to charge my phone while I was sleeping. It was at 65%. I woke 2 hours later and the phone no longer worked. Will not even turn on now.
SOURCE: The buttons...well..they don't work.
If you slept on it you might of got the keys stuck. so find one of the solved problems to open up your keypad and check if theor stuck or if the cabel is loose.
SOURCE: alarm clock not working!!
hi mate i had that same problem with my prada and thought what a load of **** . but the way i got around it is by turning the prada off take the batery cover off and take the battry out and then i put it back in power back on set my alarm and it worked!! and has ever since. hope that works for ya!
SOURCE: My voyager keeps turning off
my phone was doing the sam,e you have to go to verizon and they will tighten a screw inside then it all works again =)
SOURCE: motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
