Huawei P8 Cell Phone Logo
m
mari Posted on Apr 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When starting my camera it says:Unable to start the camera, check if there are third-party applications running in the background such as flashlight.Close them and try again. NOW: Flashlight not on.
I have restarted the phone, i have shut down the phone and I have googled everywhere! My flashlight is not on and my camera to take a selfie works it's just when I want to turn the camera around.
  • anitha
    anitha Feb 10, 2019
    Hi there I'm experiencing the same problem too
Jennies de leon
Level 2:
Habit-Forming:
New Friend:
  • Expert 102 Answers
  • Posted on Feb 11, 2019
Jennies de leon
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
102
Questions
0
Helped
22284
Points
303
Turn off and insert a memory card then turn it on again. This might help you resolve the issue. ThNkd
Russ Hill
Level 3:
  • Huawei Master 4,057 Answers
  • Posted on Jan 26, 2017
 Russ Hill
Huawei Master
Level 3:
Answers
4057
Questions
10
Helped
1177961
Points
12696
I would think the camera itself has gone if the cam don't send a picture the software would think that it's being used by another software or app. sometimes it can be that the last time you used the cam it did not shut it down properly. if you can i would try a full factory reset but check that your number etc are safe right them down etc so you don't lose them. its really the only thing you can do as the software for the camera is pre installed to the phone.
tip
How to powering back freeze computer
<p>The computer freezes for programs, many processes running in the background react and install third party software on your computer. If you do not take steps to avoid this problem, the computer will probably freeze continues and possible problems with hardware and software that may result in loss of important documents and files. Start the computer from sleep can also lead to paralysis of the computer as different programs simultaneously loaded in the background. <br /> <p><br /> <p>1. Turn the computer off and restart it from sleep. Note that your computer crashes at startup. <br /> <p><br /> <p>2. Close all third party software (software not written by Microsoft) before the computer is idle. Programs running in the background are often the reason why a computer freezes during startup. <br /> <p><br /> <p>3. Take your anti-virus program on the hard drive of your computer from viruses and spyware in the treatment of the computer and the record so he could slow down and freeze for scanning. Will remove all possible threats to your anti-virus program. <br /> <p><br /> <p>4. Press' Ctrl + Alt + Del "to open Task Manager on your computer. Close all programs that are shown as "not responding ". For unknown processes running in the background and check the registry of unnecessary memory. <br />
on Jun 22, 2011 • Computers & Internet
2helpful
Hi, i use htc wildfire a3333 which has no front camera does its back camera support for videocalling with any third party applications
The video calling applications only worl if you have a front camera on your phone, but third party apps like skype may support your main camera.
My battery dies half way through the day without even using it, is there something running on the phone draining the battery?
Hi
BBM ( blackberry messenger) could be a drain, especially with that many contacts pinging you all day long. Is your brightness on high? That is another big power drag. What apps are you running?
What themes have you installed? You can try reinstalling the OS. Check what applications are running on your device in the background, press the Menu key then choose Switch Applications. You will see the icons of each application there.
There are commonly four or five applications that will always be running (Messages, Call Logs/Phone, BlackBerry Messenger, Home screen, and the Browser; there are other third party applications such as Bee Jive, and BlackBerry Alerts which will also run in the background which you cannot close if you want them to operate). Make certain that the browser is NOT on an active webpage (open the browser and choose Menu > Close). Close any other applications that do not need to be running (the camera or a game you were playing or Google Maps).Also make certain BlackBerry Maps is not running in the background.
Do a simple reboot: With the BlackBerry device powered ON, remove the battery a few seconds and then reinsert the battery to reboot.
Now, watch your battery use the next few days again and see how it goes. Make sure you close or exit ALL applications properly: If you just hit the red "end call" key to go back to the home screen the application actually stays open and running in the background. If you do this repeatedly you will have lots of apps open and consequently your memory will get used up. Lack of memory is the biggest reason your BlackBerry slows to a crawl or locks up. If you get into the habit of actually using the menu key to close the applications this will at least slow down this battery drain and memory-clogging process.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
1helpful
Error in scanner. Turn off scanner and follow instructions in manual.Scanner driver will be closed. (code:201) Unable to open TWATN source Please check connection Then re-start Toolbox.
This error can be caused by many different issues. Try the following resolutions in order until your issue is fixed-
1. You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
2. unistall and re-install drivers-
1. Place the CanoScan Setup CD-ROM into the CD-ROM drive.
2. When the CanoScan Setup Utility menu appears, click the option to 'Uninstall the Software' and then follow the prompts.
3. Disable Third-party Software
Software applications that are active during installation can cause errors, installation difficulties and even abort the installation.*1 Close all running applications, including anti-virus programs, before installing Canon Software. You can also prevent these applications from starting through 'System Configuration Utility' (also referred to as 'msconfig') in Windows 98/Me, Windows XP and Windows Vista.
If your computer is part of an office network: Network permissions, security software, etc. may be interfering with proper communication. Please contact your System or Network Administrator before attempting to disable software on your system.
a. See your applications' documentation for instructions on how to close it.
b. If you are unable to locate the documentation or the application appears to be running after it is closed, disable the startup items in the Windows 'System Configuration Utility'.
c. If disabling startup items in 'msconfig' does not correct the issue, disable non-Microsoft related services in 'Services' tab of 'System Configuration Utility' window.
d. Attempt to install the Canon software (drivers). If the drivers were already installed, uninstall them (keep the third-party software disabled) and then reinstall the drivers.
e. After installation is complete, set 'msconfig' back to 'Normal Startup'.
//javaftper
1helpful
Sony Vaio inbuilt webcam is not working with yahoo Messenger
Webcam for vaio computer will not work with a thrid party messenger like yahoo if it is being used by another third party application.
  1. uninstall any third party applications/messenger
  2. reinstall the camera driver and software from esupport.sony.com
  3. try to use the built in camera first by uisng its own software
  4. if it will work, download and install your yahoo messenger and try to use the camera with it
I dont know how to turn camera on
Q: Camera Usage Instructions
A:
For use with systems including an Acer Orbicam, CrystalEye, or other factory installed camera.
Taking still pictures
  1. Double click the Orbicam Icon to start the program, which will open the main application screen.
  2. Set the configuration choices by clicking on the "gears" icon, which should open an additional window that slides out. Clickthe tabs and select the options for the desired settings. By default, still pictures will be sent to the "Pictures" folder.
  3. Set the resolution for still pictures by pressing the arrow under the main display. A drop down menu should appear with the available resolutions. Larger resolutions will result in larger file sizes.
  4. To take a picture, align the subject in front of the camera so that the display appears in the window as desired. Click Take Photo.
  5. The pictures should appear along the bottom of the application window if the Gallery view is enabled.
Recording video
  1. It is suggested to find a third party application to use this functionality.
Using the camera as a webcam
We cannot support third party application configuration or use.
I carnt take photo on my webcam
Issue
Camera Usage Instructions Solution
Recording video
Re-install the Web Cam:
Close all open applications on your computer and make sure your power cord is plugged into the back of the notebook.
  1. Press ‘Alt + F10' to start eRecovery Management.
  2. Enter default password of 6 zero's. Example: 000000
    (Note: if this default password does not work, then a different password has taken its place. Acer is not responsible for any forgotten or misplaced passwords.)
  3. Select ‘Recovery Actions' and click ‘Next'
  4. Select ‘Reinstall Applications/drivers' and click ‘Next'
  5. On the left hand side of the newly opened window select the following: Windows XP
    ? Driver
    ?Camera
  6. On the right side of the same window, click ‘Install Camera Driver Now'
  7. The unit will reboot after the installation is complete
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2answers
Too slow with 2GB RAM,250GB HDD and legal windows Xp
In basic terms your computer speed depends mainly on two factors:
1:System configuration
2:Software which are running in background.
Your configuration is fine so check for unwanted third party software running in background.
Steps to check it out:
Click on start
go to run
type "msconfig"
go to "startup" which is on the TOP right corner.
The list which you see here are the third party softwares which start themselves automatically when your computer boots up.
Uncheck those ones you don't need to use all the time.(Even if you uncheck all of them, It won't harm your computer)
Then click on apply then close.
restart your computer
It will give you a message >> Check on don't show this message again and then click on "OK."
You will feel your computer running better.
NOTE: some softwares like NORTON, trend micro, Mcafee. These
can also make your computer slow and we can not disable them completely from above mentioned steps. We need to disable there services as well or remove them completely.
Application running in background
That software is not so reliable.
Don't see to it untill you see some problem!
Top Huawei Cell Phones Experts
NOEL
NOEL
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
