Hi...
Thanks for choose the Fixya..
It can be helpful for you to set the correctly, and please check the connection of serial (RS232) may be they are short.
http://geoshack.com/wp-content/uploads/2011/06/GPT-3200N-NW_im.pdf
Please feel free touch us if your problem not solve.
Thanks
Prashant Sharma
SOURCE: On start up a Intel
You will need to reset your CMOS. You can do this by either removing the battery from the board for about 20 minutes than replacing it. It will automatically throw you in to your F2 or F12 setup. Or look for a jumper near the CMOS. Sometimes depending on PC Brand, just holding down a keyboard button continously during boot up will give you a keyboard error and take you to Setup. If one of the above doesn't work, hit me back on this forum and I will provide more help.
SOURCE: I am stuck in the boot up process with the option
at boot time, press F8 to boot in safe mode. then try to uninstall 1 of your recently installed software... then boot normally.
SOURCE: IBM 300 GL desk top
IBM computers use the F1 key. It is critical that the keystroke is captured at the right moment in the boot sequence. Otherwise it is ignored. Start tapping the key repeatedly as soon as you turn the system on. Shortly after the memory check and mouse initialization is complete, you should get a BIOS setup menu. If you're still having problems, you might try a different keyboard since it is always possible to have a defect there.
SOURCE: I had my battery run out, when I changed I get a
Hi, you will need to perform a windows restore using your windows CD. Insert CD in drive and select the appropriate option. You will not loose any of your work doing this.
SOURCE: My sony pcv-rx260ds win millenium
Please check your CMOS battery that is there on the motherboard try to replace with new one.
