Already had a new coil,new injector,new air flow sensor,new computer put on,plug wires and plugs checked,all with no luck.I have spent almost $1,000 in repairs the last month and going back in a few days,any help is greatly appreciated
What are the trouble codes, and what kind of car ?
Testimonial: "2009 subaru legacy,misfire 3 code is all they are telling me"
For some reason I did not see the Subaru Legacy when I answered the question. I'm sorry you have spent so much money trying to get the problem fixed. This website may not be much help since we are not there in person.
If the code is 303 it means cylinder 3 is not producing power. It does not give much info as to what to test. So the mechanic should check the three main parts, spark, fuel and compression. The computer and MAF sensor were probably a waste of money.
Someone would need to check for spark, fuel delivery, and normal compression and I doubt that has been done given your story.
So you may need to go to a different shop and start over with the basic tests. If you got a guarantee from the first shop, they should be required to fix the problem without you spending any more money, and perhaps giving you a sizable refund too.
It could be something as simple as a wiring problem where power is not getting to a coil or injector.
No warranty from the place I bought it,all this started 2 days after I got it,thanks tho I have been taking it to a mechanic at the Subaru dealership the past few times and it has him baffled also ,may try somewhere else if I can find somewhere
Hi Heidi Carpenter, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? make model and year?
2009,Subaru Legacy
