Brake light wont go on when either the hand grip is pulled or the peddle is depressed.
SOURCE: Removal of factory seat on Yamaha Royal star 1300
Hi, It opens with your key on the right side as looking from the front of the bike. Keep the key turned and pull straight up on the back of the seat. There is a tab on the front right behind the tank, so when you are putting it back make sure that tab goes into the slot first. Wow, when you get the seat off you will also find your emergency tool bag! I have royal star tour classic #41. Good Luck!
SOURCE: I have a 2005 yamaha R6 and my brake light doesn't work.
the fuse for the back light is located under the seat, its a little black box with a flip up lid. on the inside of the lid, it will show what fuse is for what componant and the amps..
SOURCE: my 2007 yamaha v star 650 keeps blowing the fuse
There seem to a 'live' wire (in the turn signal, brake light or horn circuit) touching the frame of the bike and thus the fuse blowing.
You will have to trace out the short-circuit.
You can start wth removing the connections to the turn signals thn fit the fuse and see if it still blows ....like wise remove the wire to the brake light and thn check if the fuse blows, same to the horn.
In short ..you can remove all the wires connections to these and thn fit the fuse and refit the wiring connections one by one ,where the fuse will blow after connecting the wire to say brake light thn the problem is at the brake light wiring ....likewise to the others ...onces you identify the circuit tht has the problem thn it will be easy to trace it and rectify it.
Hope this helps!
SOURCE: 2004 yamaha v star would need wiring diagram to
this is untrue if the grips are oxford hot grips they should wire str8 to the battery with the red live and black earth ringlet terminal gd luck
