Purge valve? That is part of the emission system! Nothing to do with injectors. If the injectors are not supplying fuel and the fuel pump/pressure is good, look for a bad fuse. Does the check engine light illuminate during a bulb check? Check power and ground supply to injector harness plug. If no check engine light during bulb check, suspect a fuse/power supply issue
I have 1994 chevy s10 blazer 4.3 v6 vin w at first I put new fuel pump it and it was for vin z and it did the same thing you taking about on yours then I found out that was the wrong fuel pump which it was low pressure pump for vin z which my truck takes vin w which is a high fuel pressure pump and it run find now you may have brouht a low feul pump for vin z Wichita is a low pressure pump I hope this help
You can also check you relays they can be bad that will cause it not run to?
SOURCE: my 1996 s10 blazer wont
check your fuel pressure if it doesn't have about 60 pounds of pressure it will not work
SOURCE: 95 S10 blazer won't start
check the EGR valve. it might be dirty in side with carbon. DONT GRINE OFF GASKET SCRAP IT OFF.
SOURCE: diagram on how to remove
Here is the removal procedure, and the procedure is the same for both the V-6 and the V-8 Vortec engines. Also, be certain to put engine oil on the "o"-ring seal for the fuel injector assembly before installing the upper intake. Let me know if you require any further assistance.
REMOVAL:
1. Disconnect the battery negative cable assembly from the battery negative terminal.
2. Remove the air cleaner assembly.
3. Remove the wiring harness connectors and the brackets and move aside.
4. Remove the throttle cable and the bracket from the upper intake manifold.
5. Remove the cruise control cable, (if equipped).
6. Remove the fuel lines from the intake to the rear of the block.
7. Remove the ignition coil and the bracket.
8. Remove the upper intake manifold.
INSTALLATION:
1. Install the upper intake manifold gasket.
2. Install the upper intake manifold. Use care not to pinch the injector lines between the upper and lower intake manifolds.
3. Install the upper intake manifold bolts. Note the marks made at disassembly for proper stud location. Install the two corner studs first in order to help align the two halves. NOTE: Other than the two torque passes listed below, the OE Manufacturer did NOT address or supply a bolt tightening sequence for the upper Intake Manifold for this model year, or other model years where this 2 piece manifold setup is used. A "Play It Safe" final tightening sequence would be to tighten from the center most bolts to the outer most bolts.
4. Tighten the bolts in two steps: a. Tighten the bolts on the first sequence to 5 Nm (44 inch lbs.). b. Tighten the bolts on the final sequence to 10 Nm (88 inch lbs.).
5. Install the purge solenoid and bracket.
6. Install the ignition coil and bracket.
7. Install the PCV hose et the upper intake manifold.
8. Install the fuel lines from the intake at the rear of the block.
9. Install the cruise control cable (if equipped).
10. Install the throttle cable and bracket from the upper intake manifold.
11. Install the wiring harness connectors and brackets.
12. Install the air cleaner assembly.
13. Connect the battery negative cable assembly to the battery negative terminal. - Tighten the bolt to 15 Nm (11 ft. lbs.).
SOURCE: code reading p0420 on '99
there are a couple of things to consider here. That code indicates that the O2 sensor behind the cat is not functioning like the engine computer expects-either the cat itself is not functioning properly or you may have an exhaust leak, or the heater circuit in the O2 sensor is faulty. The cat should get up to 600 degrees and it burns unburned fuel before ti gets to the 2ed O2 sensor-if it cannot do this, the CEL comes on and you have a P0420. Before replacing the cat, clear the code and see if it comes back-if it does, you might try first replacing the O2 sensor. If that doesn't work, get a 'oil fouler' spark plug adapter and install the O2 sensor in it, then install both into the exhaust-this 'shields' the tip of the O2 sensor and slows it down, fooling the engine computer into seeing it switching slowly, as it is supposed to do. Your only other choice is to replace the cat, and an aftermarket cat is much less than an OEM unit.
By the way, if you have burnt valves, a P0420 is the least of your worries.
